Introdução
I haven't seen a guide on upgrading the m.2 SSD on the 2024 ASUS Rog G14 laptop. Here is a quick guide to whoever wants to attempt at upgrading their laptop.
I used the IFIXIT Essential Electronics Toolkit for this repair and a external M.2 drive enclosure to clone (copy) the C drive.
The 2024 ASUS ROG Zephyrus G14 GA403UV laptop came with a 1TB WD SSD drive and I wanted to upgrade the storage space. On this particular laptop the RAM is LPDDR5X and it is soldered on the motherboard, it has 16GB with no way of upgrading the RAM so the only upgrade I am able to do is to upgrade the storage space. The SSD upgrade I went with was the WD_Black SN850X NVMe Gen 4 2TB 2280 M.2 drive.
I installed the new drive into an external enclosure and cloned the drive using Acronis True Image for Western Digital to copy the existing drive to the new drive. The software was a free download from the Western Digital website and I was able to make an exact copy (clone) of the boot drive C.
After the clone process was complete all that was left was to remove the 1TB drive and to install the new 2TB drive, button up the laptop and boot it up. The laptop booted up without any issues, the only thing left to do was to install the drivers for the new drive to get the max speed of the new drive.
Ferramenta utilizada neste passo:Essential Electronics Toolkit$23.96
Vantec M.2 NVMe SSD to USB 3.1 Gen 2x1 Type C Syncable RGB Enclosure
Acronis True Image for Western Digital software to make an exact copy of the existing drive onto the new drive
After the clone process is complete go ahead and shut down the laptop and remove any usb drives, dongles, and power cord from the laptop.
Flip the laptop over and put it on a soft work pad, I used the laptop sleeve to protect the lid from getting scratches on it.
Remove the 11 screws that fasten the bottom cover with the Torx 6 bit. There are 2 rubber stoppers that need to be removed to get access to 2 of the screws. I used the toolkit lid to keep the screws organized since there are a few different screw sizes.
Ferramenta utilizada neste passo:iFixit Opening Tool$1.99
After removing all 11 screws use the plastic Opening Tool to unclip the bottom cover
I started from the top right corner and worked all the way around the cover to unclip it
After the bottom cover is removed inspect the laptop internals, now is a good time to remove any dust that might have accumulated.
If you are using compressed air be careful not to overspeed the fans, I usually keep a finger on the fan to keep it from spinning while air blasting it.
Take a moment to admire/inspect the laptop for any lose wires or screws.
Ferramenta utilizada neste passo:Spudger$3.99
Before removing the SSD unhook the battery from the main board
Use the plastic Spudger Tool to remove the tape covering the battery connector
The metal cover the holds down the battery connector will need to be moved up out of the way. Once that is done you can use that Spudger Tool to pop up the battery connector.
I slid the metal cover back into position to keep the battery connector from coming in contact with the main board connection
Once the power is removed from the main board you can start working on removing the existing SSD.
Use the Phillips 1 bit to remove the single screw holding the SSD in place.
Once the screw is removed lift up the end of the SSD and pull the drive out from the PCIe slot
Once the existing drive is out simply slide the SSD out of the protective cover and slide it over the new drive
Install the new drive into the PCIe slot and reinstall the single Phillips 1 screw to hold the SSD in place.
Connect the battery back to the main board
Reinstall the cover and make sure you reseat all the clips around the edge of the cover before reinstalling the 11 screws
Finally reinstall the rubber bumpers on the bottom cover
I hooked up the power cord to make sure the charge light came on before powering the laptop back on
The laptop should boot up just fine if the clone process was successful, the only difference you should notice is a nice increase of storage space!
Congratulations you just upgraded you ASUS ROG Zephyrus G14 laptop!
