Introdução
This is a step by step process for the replacement or repair of the webcam on your Asus ROG Strix GL702VS laptop. If you are experiencing bad quality or a black screen while using the webcam, follow these steps to remove the webcam and replace it.
O que você precisa
Remove the two screw stickers at the bottom corners of the screen.
Remove the two 4mm JIS #0 screws beneath the stickers.
Gently lift the webcam out of its resting position at the top of the LCD assembly.
Uma outra pessoa concluiu este guia.
