Ir para o conteúdo principal
Asus ROG Strix GL702VS Webcam Replacement
O que você precisa
  1. Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): passo 1, imagem 1 %32 Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): passo 1, imagem 2 %32 Asus ROG Strix GL702VS Webcam Replacement, LCD Screen (Display): passo 1, imagem 3 %32
    • Remove the two screw stickers at the bottom corners of the screen.
    • Remove the two 4mm JIS #0 screws beneath the stickers.
  2. Asus ROG Strix GL702VS Webcam Replacement: passo 2, imagem 1 %32 Asus ROG Strix GL702VS Webcam Replacement: passo 2, imagem 2 %32 Asus ROG Strix GL702VS Webcam Replacement: passo 2, imagem 3 %32
    • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
    • Using an opening tool, lift up the bezel once the glue has been removed.
    • The plastic clips remain so it will have some resistance/snapping noises.
  3. Asus ROG Strix GL702VS Webcam Replacement: passo 3, imagem 1 %32 Asus ROG Strix GL702VS Webcam Replacement: passo 3, imagem 2 %32
    • Lift the plastic bezel off of the front display panel.
    • The plastic bezel will click when put back on the screen.
  4. Asus ROG Strix GL702VS Webcam Replacement: passo 4, imagem 1 %32
    • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
  5. Asus ROG Strix GL702VS Webcam Replacement: passo 5, imagem 1 %32 Asus ROG Strix GL702VS Webcam Replacement: passo 5, imagem 2 %32 Asus ROG Strix GL702VS Webcam Replacement: passo 5, imagem 3 %32
    • Once the LCD display is freed you can lift it up out of the casing.
    • Be careful as the cable remains attached.
  6. Asus ROG Strix GL702VS Webcam Replacement: passo 6, imagem 1 %32 Asus ROG Strix GL702VS Webcam Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
    • Once fully disconnected, remove the LCD and replace it.
  7. Asus ROG Strix GL702VS Webcam Replacement, Webcam: passo 7, imagem 1 %32
    • Gently lift the webcam out of its resting position at the top of the LCD assembly.
  8. Asus ROG Strix GL702VS Webcam Replacement: passo 8, imagem 1 %32 Asus ROG Strix GL702VS Webcam Replacement: passo 8, imagem 2 %32
    Comprar
    • Using the nylon tweezers or your hand, disconnect the webcam module.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 544
