Ir para o conteúdo principal
Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement
O que você precisa
  1. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: passo 1, imagem 1 %32 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: passo 1, imagem 2 %32
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: passo 2, imagem 1 %32 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: passo 2, imagem 2 %32 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: passo 2, imagem 3 %32
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
  4. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: passo 4, imagem 1 %32
    • Pull the hard drive directly away from the fan just above it.
    • The connecting pins should slide out easily, but you might have to move the hard drive around a bit to loosen the pins.
Conclusão
8 outras pessoas executaram este guia.
Zach Langer
Membro desde: 04/10/17
676 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S13-G2, Forte Spring 2017 Membro de Cal Poly, Team S13-G2, Forte Spring 2017
CPSU-FORTE-S17S13G2
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 33
Ao todo: 7,604
