O que você precisa
Remove 10 screws.
Note: front screws (blue) are 10mm long, central and rear (brown) are 12mm.
Antenna (orange)
Speakers (yellow)
Power and miscellaneous LED (blue)
Keyboard (green)
Display (pink)
Lift locking mechanism up
Pull ribbon cable from connector
Lift locking tab on each connector (3x)
Pull each ribbon cable out
Remove screw holding display cable
Remove plastic shield over display cable
Pull cable out of the clip
Carefully holding by metal part pull connector up.
Repeat for second connector.
Remove remaining hinges screws (5)
Note: one screw was holding display cable.
Remove two side motherboard screws (yellow marks)
Remove 4 center screws (green marks)
Note: side screws silver and slighter longer.
NOTE: Headset connector is holding in the case.
Lift motherboard from HDMI connector side and pull towards it.
Remove radio module screw (red) and pull it out of connector.
Disconnect fans connectors and remove 6x screws. Pull fans out.
Remove 8 screws from heat sink and remove it.
Note: heat sink use thermal paste on CPU and GPU - you will need to clean and use new before putting it together.
Um comentário
Hello I am interested motherboard, how much it's the price ?
