Ir para o conteúdo principal
Asus ROG GL551J Screen Replacement
O que você precisa
  1. Asus ROG GL551J Screen Replacement, Battery: passo 1, imagem 1 %32
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Screen Replacement: passo 2, imagem 1 %32
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Screen Replacement: passo 3, imagem 1 %32
    • Pull the battery out.
  4. Asus ROG GL551J Screen Replacement, Screen: passo 4, imagem 1 %32 Asus ROG GL551J Screen Replacement, Screen: passo 4, imagem 2 %32
    • Use a plastic opening tool to remove the plastic hinge covers on either side of the laptop.
  5. Asus ROG GL551J Screen Replacement: passo 5, imagem 1 %32 Asus ROG GL551J Screen Replacement: passo 5, imagem 2 %32
    • Remove the middle screws located on either side of the display.
  6. Asus ROG GL551J Screen Replacement: passo 6, imagem 1 %32 Asus ROG GL551J Screen Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to pop out the bezel from all four sides, then lift it out of the frame.
    • When doing this in reverse during reassembly, try closing the laptop and applying pressure to reattach the bezel snaps.
  7. Asus ROG GL551J Screen Replacement: passo 7, imagem 1 %32
    • Remove the screws at each corner of the display.
  8. Asus ROG GL551J Screen Replacement: passo 8, imagem 1 %32 Asus ROG GL551J Screen Replacement: passo 8, imagem 2 %32
    • Remove the connector from the display by pulling the wire downwards.
    • Be sure to take note of the orientation of the connector when unplugging and plugging in.
Conclusão
Uma outra pessoa concluiu este guia.
Thien Vu
Membro desde: 02/15/17
412 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-4, Lacy Spring 2017 Membro de USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
Membros da 4
Autoria de 5 guias
Um comentário
Hey, I am having issues putting the plastic hinge caps back on after I'm done. I know there is a right one and a left one but I just don't know how to pop them back into place. Starting to get a bit desperate. Could anyone give me some tips?
Thanks!
Teodor Andonov - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 23
Duração total: 3,095
