Ir para o conteúdo principal
Asus ROG GL551J Optical Drive Replacement
O que você precisa
  1. Asus ROG GL551J Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Optical Drive Replacement: passo 2, imagem 1 %32
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Optical Drive Replacement: passo 3, imagem 1 %32
    • Pull the battery out.
  4. Asus ROG GL551J Optical Drive Replacement, Optical Drive: passo 4, imagem 1 %32 Asus ROG GL551J Optical Drive Replacement, Optical Drive: passo 4, imagem 2 %32
    • Locate and unscrew the screw which connects the optical drive to the chassis
  5. Asus ROG GL551J Optical Drive Replacement: passo 5, imagem 1 %32
    • Grasp the edge of the optical drive
  6. Asus ROG GL551J Optical Drive Replacement: passo 6, imagem 1 %32
    • Pull on the optical drive gently. With little resistance, the optical drive should just slide out
Conclusão
4 outras pessoas executaram este guia.
Philip Muino
Membro desde: 02/15/17
179 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 5-4, Lacy Spring 2017 Membro de USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
Membros da 4
Autoria de 5 guias
Um comentário
ok.so , if someone had replaced the dvd rom with a hard disk drive i nust do the same for replace the drive?
anix - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 2,004
