Ir para o conteúdo principal
Asus ROG GL551J Hard Drive Replacement
O que você precisa
  1. Asus ROG GL551J Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Hard Drive Replacement: passo 2, imagem 1 %32
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Hard Drive Replacement: passo 3, imagem 1 %32
    • Pull the battery out.
  4. Asus ROG GL551J Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Asus ROG GL551J Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • With laptop upside-down, locate and unscrew the two screws on the panel with the vents.
    • Slide the panel out and lift up to remove.
  5. Asus ROG GL551J Hard Drive Replacement: passo 5, imagem 1 %32 Asus ROG GL551J Hard Drive Replacement: passo 5, imagem 2 %32
    • The hard drive is the metal rectangle with the two soft padding bars attached to it.
    • Locate and remove the 4 screws holding the hard drive down at each corner using a PH000 Philips head.
  6. Asus ROG GL551J Hard Drive Replacement: passo 6, imagem 1 %32 Asus ROG GL551J Hard Drive Replacement: passo 6, imagem 2 %32
    • Locate the black plastic tab attached to the bottom of the hard drive and pull it straight outwards.
    • Failure to correctly disconnect the hard drive before pulling it up and out can damage the connectors.
    • Once the hard drive detaches from the connector, lift the hard drive up and out.
Conclusão
7 outras pessoas executaram este guia.
Thien Vu
Membro desde: 02/15/17
412 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-4, Lacy Spring 2017 Membro de USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 4,522
