Ir para o conteúdo principal
Asus ROG GL551J Battery Replacement
  1. Asus ROG GL551J Battery Replacement, Battery: passo 1, imagem 1 %32
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Battery Replacement: passo 2, imagem 1 %32
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Battery Replacement: passo 3, imagem 1 %32
    • Pull the battery out.
Conclusão
4 outras pessoas executaram este guia.
Jason Nguyen
Membro desde: 02/20/17
356 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-4, Lacy Spring 2017 Membro de USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
Membros da 4
Autoria de 5 guias
Um comentário
I need a guide to replace the MOTHERBOARD!! Do you guys have one of those? If not, do you have one that shows replacing the CMOS battery?
PLEASE HELP!!! I love this laptop and it’s only 4 years old and it’s DEAD!!!
Thank you,
Jana
hockeyblades - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,888
