Ir para o conteúdo principal
Asus ROG G751JT-DH72 RAM Replacement
O que você precisa
  1. Asus ROG G751JT-DH72 RAM Replacement, RAM: passo 1, imagem 1 %32 Asus ROG G751JT-DH72 RAM Replacement, RAM: passo 1, imagem 2 %32
    • Lift up the rubber tab located in the upper-right corner of the backing plate.
  2. Asus ROG G751JT-DH72 RAM Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
  3. Asus ROG G751JT-DH72 RAM Replacement: passo 3, imagem 1 %32
    • Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
  4. Asus ROG G751JT-DH72 RAM Replacement: passo 4, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the 5mm screw on the right side.
  5. Asus ROG G751JT-DH72 RAM Replacement: passo 5, imagem 1 %32
    • Pull out the optical drive to revel the screws holding the laptop cover.
  6. Asus ROG G751JT-DH72 RAM Replacement: passo 6, imagem 1 %32 Asus ROG G751JT-DH72 RAM Replacement: passo 6, imagem 2 %32
    • Remove all 10 5.2mm Phillips screws holding the main back cover using the Phillips #1 screwdriver.
  7. Asus ROG G751JT-DH72 RAM Replacement: passo 7, imagem 1 %32
    • Remove the four 5.2mm screws directly behind the backing plate using the Phillips #1 screwdriver.
  8. Asus ROG G751JT-DH72 RAM Replacement: passo 8, imagem 1 %32
    • Flip over the laptop and pry the 2 vent covers off.
  9. Asus ROG G751JT-DH72 RAM Replacement: passo 9, imagem 1 %32
    • Remove the two 6.8mm Phillips screws directly below the vent covers using the Phillips #1 screwdriver.
  10. Asus ROG G751JT-DH72 RAM Replacement: passo 10, imagem 1 %32 Asus ROG G751JT-DH72 RAM Replacement: passo 10, imagem 2 %32
    • Pry along the edges of the keyboard to lift it up.
    • Be careful not to damage the ribbon connectors.
  11. Asus ROG G751JT-DH72 RAM Replacement: passo 11, imagem 1 %32 Asus ROG G751JT-DH72 RAM Replacement: passo 11, imagem 2 %32
    • Disconnect all 4 ribbon connectors with a tweezer.
  12. Asus ROG G751JT-DH72 RAM Replacement: passo 12, imagem 1 %32
    • Carefully, pull on the side tabs to release the RAM card.
Conclusão
Anum Haidari
Membro desde: 10/22/18
558 Reputação
Autoria de 3 guias
Equipe
UC Davis, Team S7-G4, Lore Fall 2018 Membro de UC Davis, Team S7-G4, Lore Fall 2018
UCD-LORE-F18S7G4
Membros da 2
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 1,124
