Ir para o conteúdo principal
Asus ROG G751JL-DS71 Hard Drive Replacement
O que você precisa
  1. Asus ROG G751JL-DS71 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Asus ROG G751JL-DS71 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Asus ROG G751JL-DS71 Hard Drive Replacement: passo 2, imagem 1 %32 Asus ROG G751JL-DS71 Hard Drive Replacement: passo 2, imagem 2 %32 Asus ROG G751JL-DS71 Hard Drive Replacement: passo 2, imagem 3 %32
    • Use the black nylon spudger to pry the back panel off the laptop.
  3. Asus ROG G751JL-DS71 Hard Drive Replacement: passo 3, imagem 1 %32 Asus ROG G751JL-DS71 Hard Drive Replacement: passo 3, imagem 2 %32 Asus ROG G751JL-DS71 Hard Drive Replacement: passo 3, imagem 3 %32
    • Use a Phillips 1 Screwdriver to remove the four 2.4 mm screws securing the hard drive.
    • Use the black pull-tab located on the shell covering the hard drive, to lift the hard drive housing and pull the hard drive away from the connector.
    • To access the hard drive on the right side of the laptop, perform the same steps, but on hard drive casing to the right of the previous hard drive.
Conclusão
Vincent Guarino
Membro desde: 01/22/18
190 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S16-G1, Banghart Winter 2018 Membro de Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
Membros da 4
Autoria de 22 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 509
