Ir para o conteúdo principal
Asus ROG G751JL-DS71 Fan Replacement
O que você precisa
  1. Asus ROG G751JL-DS71 Fan Replacement, Fan: passo 1, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement, Fan: passo 1, imagem 2 %32
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Asus ROG G751JL-DS71 Fan Replacement: passo 2, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 2, imagem 2 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 2, imagem 3 %32
    • Use the standard spudger to remove the back center panel.
  3. Asus ROG G751JL-DS71 Fan Replacement: passo 3, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 3, imagem 2 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 3, imagem 3 %32
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Asus ROG G751JL-DS71 Fan Replacement: passo 4, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 4, imagem 2 %32
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Fan Replacement: passo 5, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 5, imagem 2 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 5, imagem 3 %32
    • Remove the screws holding the hard drives in place using a phillips #1 screwdriver.
    • Using the small flaps, remove the hard drives by hand.
  6. Asus ROG G751JL-DS71 Fan Replacement: passo 6, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  7. Asus ROG G751JL-DS71 Fan Replacement: passo 7, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 7, imagem 2 %32
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  8. Asus ROG G751JL-DS71 Fan Replacement: passo 8, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 8, imagem 2 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 8, imagem 3 %32
    • Use a metal spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  9. Asus ROG G751JL-DS71 Fan Replacement: passo 9, imagem 1 %32
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
  10. Asus ROG G751JL-DS71 Fan Replacement: passo 10, imagem 1 %32
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
  11. Asus ROG G751JL-DS71 Fan Replacement: passo 11, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 11, imagem 2 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 11, imagem 3 %32
    • Use a metal opening tool to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  12. Asus ROG G751JL-DS71 Fan Replacement: passo 12, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 12, imagem 2 %32
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  13. Asus ROG G751JL-DS71 Fan Replacement: passo 13, imagem 1 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 13, imagem 2 %32 Asus ROG G751JL-DS71 Fan Replacement: passo 13, imagem 3 %32
    • Disconnect the four-pin connectors from each fan and remove them
    • The fans are now completely disconnected from the laptop and you can remove them
Conclusão
Uma outra pessoa concluiu este guia.
Ashley Twigg
Membro desde: 04/01/19
237 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S8-G8, Wilson Spring 2019 Membro de IUPUI, Team S8-G8, Wilson Spring 2019
IUPUI-WILSON-S19S8G8
Membros da 4
Autoria de 3 guias
Um comentário
i was wondering if i can swap the bottom case of g751jl with bottom case of g751jy? thanks a ton
Avkash - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 979
