Ir para o conteúdo principal
Asus ROG G751JL-BSI7T28 USB Port Board Replacement
O que você precisa
  1. Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Back Panel: passo 1, imagem 1 %32
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 2, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 2, imagem 2 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 2, imagem 3 %32
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Display Assembly: passo 3, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Display Assembly: passo 3, imagem 2 %32
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 4, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 4, imagem 2 %32
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 5, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 5, imagem 2 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 5, imagem 3 %32
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 6, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 6, imagem 2 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 6, imagem 3 %32
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 7, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 7, imagem 2 %32
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Keyboard Assembly: passo 8, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Keyboard Assembly: passo 8, imagem 2 %32
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Fan: passo 9, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement, Fan: passo 9, imagem 2 %32
    • Remove the fan's power cable by pulling carefully outward towards the fan.
  10. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 10, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 10, imagem 2 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 10, imagem 3 %32
    • Remove the 5mm Phillips #00 screw.
    • Pull up on the black tab connected to the fan. This will pull it away from the cooling fins, allowing it to be removed.
    • Remove the fan from the laptop.
  11. Asus ROG G751JL-BSI7T28 USB Port Board Replacement, USB Port Board: passo 11, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement, USB Port Board: passo 11, imagem 2 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement, USB Port Board: passo 11, imagem 3 %32
    • Remove the three 5mm Phillips #0 screws from the USB port board.
    • Lift the USB port board out of the laptop.
  12. Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 12, imagem 1 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 12, imagem 2 %32 Asus ROG G751JL-BSI7T28 USB Port Board Replacement: passo 12, imagem 3 %32
    • Pull the data cable out of the USB port board.
Conclusão
Dylan Michael Leonard
Membro desde: 11/05/19
423 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S1-G1, Barthe Fall 2019 Membro de UMass Dartmouth, Team S1-G1, Barthe Fall 2019
UMASSD-BARTHE-F19S1G1
Membros da 3
Autoria de 4 guias
2 comentários
Hi Dylan. I inherited an older G751JL-BSI7T28 Asus gaming laptop. Do you know if the internal graphics card was able to be replaced by anything other than the 2GB Geforce that is in it? I hate top put money in an older laptop but other than it doesnt have USB C or USB 3.1, it really isn’t that bad of a laptop for its age.
cpruitt1@carolina.rr.com
cpruitt1 - Responder
The laptop is very formidable for it’s age but unfortunately the laptop’s GPU is integrated into the motherboard, so it cannot be swapped out. Hope this helps!
Dylan Michael Leonard - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 265
