Ir para o conteúdo principal
Asus ROG G751JL-BSI7T28 Fan Replacement
O que você precisa
  1. Asus ROG G751JL-BSI7T28 Fan Replacement, Back Panel: passo 1, imagem 1 %32
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Fan Replacement: passo 2, imagem 1 %32 Asus ROG G751JL-BSI7T28 Fan Replacement: passo 2, imagem 2 %32 Asus ROG G751JL-BSI7T28 Fan Replacement: passo 2, imagem 3 %32
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Fan Replacement, Display Assembly: passo 3, imagem 1 %32 Asus ROG G751JL-BSI7T28 Fan Replacement, Display Assembly: passo 3, imagem 2 %32
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Fan Replacement: passo 4, imagem 1 %32 Asus ROG G751JL-BSI7T28 Fan Replacement: passo 4, imagem 2 %32
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Fan Replacement: passo 5, imagem 1 %32 Asus ROG G751JL-BSI7T28 Fan Replacement: passo 5, imagem 2 %32 Asus ROG G751JL-BSI7T28 Fan Replacement: passo 5, imagem 3 %32
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Fan Replacement: passo 6, imagem 1 %32 Asus ROG G751JL-BSI7T28 Fan Replacement: passo 6, imagem 2 %32 Asus ROG G751JL-BSI7T28 Fan Replacement: passo 6, imagem 3 %32
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Fan Replacement: passo 7, imagem 1 %32 Asus ROG G751JL-BSI7T28 Fan Replacement: passo 7, imagem 2 %32
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 Fan Replacement, Keyboard Assembly: passo 8, imagem 1 %32 Asus ROG G751JL-BSI7T28 Fan Replacement, Keyboard Assembly: passo 8, imagem 2 %32
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 Fan Replacement, Fan: passo 9, imagem 1 %32 Asus ROG G751JL-BSI7T28 Fan Replacement, Fan: passo 9, imagem 2 %32
    • Remove the fan's power cable by pulling carefully outward towards the fan.
  10. Asus ROG G751JL-BSI7T28 Fan Replacement: passo 10, imagem 1 %32 Asus ROG G751JL-BSI7T28 Fan Replacement: passo 10, imagem 2 %32 Asus ROG G751JL-BSI7T28 Fan Replacement: passo 10, imagem 3 %32
    • Remove the 5mm Phillips #00 screw.
    • Pull up on the black tab connected to the fan. This will pull it away from the cooling fins, allowing it to be removed.
    • Remove the fan from the laptop.
Conclusão
Kristen Gismondi
Membro desde: 11/12/14
82.689 Reputação
Autoria de 202 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.420 guias
Um comentário
What's the fan model?
Andres Landazuri - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 661
