Ir para o conteúdo principal
Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement
O que você precisa
  1. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: passo 1, imagem 1 %32 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement, Soundbar/speaker: passo 1, imagem 2 %32
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 2, imagem 1 %32 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 2, imagem 2 %32
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 3, imagem 1 %32 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 3, imagem 2 %32
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  4. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 4, imagem 1 %32 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 4, imagem 2 %32
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  5. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 5, imagem 1 %32 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 5, imagem 2 %32 Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 5, imagem 3 %32
    • Begin prying up on the plate as shown in the pictures.
  6. Asus ROG G750JM-BSI7N23 Soundbar/speaker Replacement: passo 6, imagem 1 %32
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 387
