Ir para o conteúdo principal
Asus ROG G750JM-BS17N23 Hard Drive Replacement
O que você precisa
  1. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Back Plate: passo 1, imagem 1 %32
    • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
  2. Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 2, imagem 1 %32
    • Retract the Phillips #2 screw until the cover is loose.
    • The screw will not come all the way out.
  3. Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 3, imagem 1 %32 Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 3, imagem 2 %32 Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 3, imagem 3 %32
    • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
  4. Asus ROG G750JM-BS17N23 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • To access the hard drive, remove the back plate.
  5. Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 5, imagem 1 %32 Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 5, imagem 2 %32
    • Remove the three 4mm Phillips #2 screws.
  6. Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 6, imagem 1 %32 Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 6, imagem 2 %32
    • Pull back on the tab on the hard drive shield until it is clear of the screw slots. Next pull the shield out.
  7. Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 7, imagem 1 %32 Asus ROG G750JM-BS17N23 Hard Drive Replacement: passo 7, imagem 2 %32
    • With the hard drive exposed, pull the hard drive away from the connection point and then remove the hard drive.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 492
