Introdução
If you are looking for guidance on how to disassemble the Asus ROG G750JH-DB71, this guide is for you.
Potential reasons one may be interested in dissembling a laptop include needing to clean or fix internal hardware, scrapping parts for a project, general interest in how a computer functions, and more.
Before beginning disassembly, make sure your your laptop is powered off completely, and disconnect from any external power source.
O que você precisa
Use a spudger or your finger to lift up the plastic cover on the bottom of the laptop.
Under the plastic cover is a captive screw; unscrew it using a Phillips #00 screwdriver.
Remove the hard drive by unscrewing the 4.4 mm Phillips #00 screws.
Remove all of the plastic caps around the edges using a pick or flathead screwdriver, and remove the screws underneath them. (one 13 mm Phillips #00, six 8 mm Phillips #00)
Remove the remaining screws underneath the cover . (six 8mm Phillips #00, three 1 mm Phillips #00)
