Ir para o conteúdo principal
Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement
O que você precisa
  1. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: passo 1, imagem 1 %32 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: passo 1, imagem 2 %32
    • Place the device upside-down. Unscrew the screw at the top of the cover and remove the cover by using a plastic opening tool.
  2. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: passo 2, imagem 1 %32
    • Remove the screw that is located on the right edge of the removed cover. The screw is in a small opening.
  3. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: passo 3, imagem 1 %32 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: passo 3, imagem 2 %32
    • Inside the opening that the screw was in, use a nylon spudger or any thin tool to push against the inside edge of the disc/optical drive.
    • With the disc/optical drive slightly popped out of the socket, pull the rest of it out by hand.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 258
