Ir para o conteúdo principal
Asus ROG G74SX-DH73-3D Battery Replacement
O que você precisa
  1. Asus ROG G74SX-DH73-3D Battery Replacement, Battery: passo 1, imagem 1 %32 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: passo 1, imagem 2 %32 Asus ROG G74SX-DH73-3D Battery Replacement, Battery: passo 1, imagem 3 %32
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
Conclusão
2 comentários
The note bullet should just be a bullet. Check grammar on the Red bullet.
Joseph McCoy - Responder
“With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.” The sentence is too wordy you can remove “Where you can see the battery pop slightly up”.
Nicholas Ivey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 354
