Introdução
Replace a broken or noisy fan.
Before starting on this guide, unplug the laptop from its charger and turn the laptop off.
O que você precisa
Push the slider to the opposite side, while pulling out the battery.
Remove the battery from the device.
Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
Remove the cover for the hard drive by pushing down and sliding it towards yourself.
Unplug the red and yellow wires from the port in the motherboard.
Lightly pull on the red and yellow wires to release.
