Ir para o conteúdo principal
Asus ROG G56JK CD Drive Replacement
O que você precisa
  1. Asus ROG G56JK CD Drive Replacement, Battery: passo 1, imagem 1 %32 Asus ROG G56JK CD Drive Replacement, Battery: passo 1, imagem 2 %32
    • Push the slider to the opposite side, while pulling out the battery.
    • Remove the battery from the device.
  2. Asus ROG G56JK CD Drive Replacement, Hard Drive: passo 2, imagem 1 %32
    • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
    • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
  3. Asus ROG G56JK CD Drive Replacement: passo 3, imagem 1 %32
    • Slide the hard drive to left and remove it from the device.
  4. Asus ROG G56JK CD Drive Replacement, Back Panel: passo 4, imagem 1 %32
    • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
  5. Asus ROG G56JK CD Drive Replacement: passo 5, imagem 1 %32
    • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
    • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
  6. Asus ROG G56JK CD Drive Replacement, CD Drive: passo 6, imagem 1 %32
    • Using a Phillips #0 screwdriver, unscrew the four 4mm screws.
  7. Asus ROG G56JK CD Drive Replacement: passo 7, imagem 1 %32
    • Gently pull the CD drive out of the side of the laptop and remove it from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 732
