Ir para o conteúdo principal
Asus ROG G55VW-DH71 Sound Bar Replacement
O que você precisa
  1. Asus ROG G55VW-DH71 Sound Bar  Replacement, Sound Bar: passo 1, imagem 1 %32 Asus ROG G55VW-DH71 Sound Bar  Replacement, Sound Bar: passo 1, imagem 2 %32
    • Side the switch and lift the battery from the back of the device.
  2. Asus ROG G55VW-DH71 Sound Bar  Replacement: passo 2, imagem 1 %32 Asus ROG G55VW-DH71 Sound Bar  Replacement: passo 2, imagem 2 %32
    • Using the PH0 screw driver remove both 4.4 mm screws.
    • Using the PH0 screw driver remove the 6.4 mm screw.
  3. Asus ROG G55VW-DH71 Sound Bar  Replacement: passo 3, imagem 1 %32 Asus ROG G55VW-DH71 Sound Bar  Replacement: passo 3, imagem 2 %32
    • Using the iFixit opening tool, gently pry open the plate covering the spine of the device.
  4. Asus ROG G55VW-DH71 Sound Bar  Replacement: passo 4, imagem 1 %32
    • Using the PH 00 screwdriver, remove the three 10.6 mm screws holding the sound bar down.
  5. Asus ROG G55VW-DH71 Sound Bar  Replacement: passo 5, imagem 1 %32 Asus ROG G55VW-DH71 Sound Bar  Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the bent black tweezers, remove both wires connecting the sound bar to the motherboard.
Conclusão
Um comentário
Excellent tutorial. Thank you for your help.Excellent tutorial. Thank you for your help. I lost the back cover of my g55. I couldn't find a spare part here in Brazil.
Welington Faria - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 305
