Introdução
This replacement guide will aid users in upgrading their Random Access Memory cards also known as RAM cards. Doing this is one way to make a device run faster and overall upgrade it's performance.
This is not a cure all solution but it will aid in the speed at which the device can navigate through its programmes.
O que você precisa
Flip the device over so that the bottom of the computer is easily accessible.
Using the Phillips size 0 head screwdriver, remove both 3.6mm. screws on the back plate located on the bottom left portion of the back of the laptop.
