Ir para o conteúdo principal
Asus ROG G55VW-DH71 RAM Replacement
O que você precisa
  1. Asus ROG G55VW-DH71 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Flip the device over so that the bottom of the computer is easily accessible.
    • Using the Phillips size 0 head screwdriver, remove both 3.6mm. screws on the back plate located on the bottom left portion of the back of the laptop.
  2. Asus ROG G55VW-DH71 RAM Replacement: passo 2, imagem 1 %32
    • Lift up and remove the back plate from the device.
  3. Asus ROG G55VW-DH71 RAM Replacement: passo 3, imagem 1 %32
    • Gently pry apart the two white clips, that are holding in the RAM cards in, outwards.
  4. Asus ROG G55VW-DH71 RAM Replacement: passo 4, imagem 1 %32
    • Lift then gently pull out the RAM card.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 669
