Ir para o conteúdo principal
Asus ROG G53SW-XT1 Back Panel Replacement
O que você precisa
  1. Asus ROG G53SW-XT1 Back Panel Replacement, Battery: passo 1, imagem 1 %32
    • Unplug the power cable and flip the computer over.
  2. Asus ROG G53SW-XT1 Back Panel Replacement: passo 2, imagem 1 %32
    • Unlock the battery by pushing the switch to the right.
  3. Asus ROG G53SW-XT1 Back Panel Replacement: passo 3, imagem 1 %32 Asus ROG G53SW-XT1 Back Panel Replacement: passo 3, imagem 2 %32
    • Push and hold the left switch, then pull the battery out.
  4. Asus ROG G53SW-XT1 Back Panel Replacement, Keyboard: passo 4, imagem 1 %32 Asus ROG G53SW-XT1 Back Panel Replacement, Keyboard: passo 4, imagem 2 %32 Asus ROG G53SW-XT1 Back Panel Replacement, Keyboard: passo 4, imagem 3 %32
    • Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
  5. Asus ROG G53SW-XT1 Back Panel Replacement: passo 5, imagem 1 %32 Asus ROG G53SW-XT1 Back Panel Replacement: passo 5, imagem 2 %32 Asus ROG G53SW-XT1 Back Panel Replacement: passo 5, imagem 3 %32
    • Disconnect the keyboard ribbon cables from the motherboard.
  6. Asus ROG G53SW-XT1 Back Panel Replacement, Back Panel: passo 6, imagem 1 %32 Asus ROG G53SW-XT1 Back Panel Replacement, Back Panel: passo 6, imagem 2 %32 Asus ROG G53SW-XT1 Back Panel Replacement, Back Panel: passo 6, imagem 3 %32
    • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
  7. Asus ROG G53SW-XT1 Back Panel Replacement: passo 7, imagem 1 %32
    • Remove the fourteen Phillips #0 screws.
  8. Asus ROG G53SW-XT1 Back Panel Replacement: passo 8, imagem 1 %32 Asus ROG G53SW-XT1 Back Panel Replacement: passo 8, imagem 2 %32
    • Flip the laptop over and pull off the bottom cover.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 666
