Ir para o conteúdo principal
Asus R558UQ-DM513D SSD Replacement
O que você precisa
  1. Asus R558UQ-DM513D SSD Replacement, HDD (Hard Disk Drive): passo 1, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the single 5 mm screw and remove the RAM access panel.
    • Remove the ten 5 mm screws using the same Phillips #0 screwdriver.
  2. Asus R558UQ-DM513D SSD Replacement: passo 2, imagem 1 %32
    • Remove two 2 mm hidden screws using the Phillips #0 screwdriver.
  3. Asus R558UQ-DM513D SSD Replacement: passo 3, imagem 1 %32
    • Remove the back cover of the laptop to expose the inner components.
  4. Asus R558UQ-DM513D SSD Replacement: passo 4, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the HDD in place.
  5. Asus R558UQ-DM513D SSD Replacement: passo 5, imagem 1 %32
    • Gently take the left-side board containing the ports by simply sliding it in and taking it out while still connected to the wire.
  6. Asus R558UQ-DM513D SSD Replacement: passo 6, imagem 1 %32
    • Slide the HDD out.
Conclusão
Deepanker Seth
Membro desde: 12/05/20
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 132
Ao todo: 1,883
