Ir para o conteúdo principal
Asus R541UA-RB51 Hard Drive Replacement
O que você precisa
  1. Asus R541UA-RB51 Hard Drive Replacement, Keyboard: passo 1, imagem 1 %32 Asus R541UA-RB51 Hard Drive Replacement, Keyboard: passo 1, imagem 2 %32 Asus R541UA-RB51 Hard Drive Replacement, Keyboard: passo 1, imagem 3 %32
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 Hard Drive Replacement: passo 2, imagem 1 %32 Asus R541UA-RB51 Hard Drive Replacement: passo 2, imagem 2 %32
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 Hard Drive Replacement: passo 3, imagem 1 %32 Asus R541UA-RB51 Hard Drive Replacement: passo 3, imagem 2 %32
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
  4. Asus R541UA-RB51 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Asus R541UA-RB51 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Locate the hard drive in the lower right hand corner in the computer. This device did not have a hard drive so a piece of cardboard was used as a substitute.
    • Remove the two 5.7 mm screws from the base. Use a Phillips #1 screwdriver to remove the screws. Lift up to remove the hard drive.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 688
