Introdução
This guide demonstrates how to replace a broken hard drive in an ASUS laptop with a new one. This guide is shown using a solid-state drive (SSD) as a replacement, but a classic hard drive (HDD) will do.
O que você precisa
Use a Phillips #0 screwdriver to remove the ten screws from the back cover.
Flip the laptop over and open the case.
Use a plastic opening pick or card to pry at the seams between the plastic palm rests and the back cover.
Pry all around the case to release the plastic clips, but do not completely remove the palm rest as there are still cables connecting it to the case.
Insert your new storage drive (Solid State Drive shown here) into the enclosure and secure it with the screws used previously.
Insert the drive into the bay and slide it to the left to reconnect it to the motherboard.
Replace the two screws to hold the enclosure in place using a Phillips #0 screwdriver.
Uma outra pessoa concluiu este guia.
