Ir para o conteúdo principal
Asus R510CA-OB01 Keyboard and Mousepad Replacement
O que você precisa
  1. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: passo 1, imagem 1 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: passo 1, imagem 2 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: passo 1, imagem 3 %32
    • Locate the two switches that lock the battery.
    • Then, push the right switch outward to unlock it.
  2. Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 2, imagem 1 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 2, imagem 2 %32
    • Push the left switch outward and push the battery upward at the same time.
  3. Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 3, imagem 1 %32
    • Use a Li-ion battery as a replacement for your battery.
  4. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Keyboard and Mousepad: passo 4, imagem 1 %32
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computers that it is upside down. Position the computer with the front towards you.
  5. Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 5, imagem 1 %32
    • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
  6. Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 6, imagem 1 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 6, imagem 2 %32
    • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
  7. Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 7, imagem 1 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 7, imagem 2 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 7, imagem 3 %32
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  8. Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 8, imagem 1 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 8, imagem 2 %32
    • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
  9. Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 9, imagem 1 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 9, imagem 2 %32
    • Turn the laptop the right way up and face it towards you.
    • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
    • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
  10. Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 10, imagem 1 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 10, imagem 2 %32
    • Make sure that the entire cover has been released front the plastic pins.
    • Slowly lift the cover open from the front of the laptop but do not completely remove.
    • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
  11. Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 11, imagem 1 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 11, imagem 2 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 11, imagem 3 %32
    • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
    • The cable will slide out of its place.
  12. Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 12, imagem 1 %32 Asus R510CA-OB01 Keyboard and Mousepad Replacement: passo 12, imagem 2 %32
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
Conclusão
Blanche Pinto
Membro desde: 09/28/17
437 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S3-G4, Nance Fall 2017 Membro de USF Tampa, Team S3-G4, Nance Fall 2017
USFT-NANCE-F17S3G4
Membros da 2
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 774
