Ir para o conteúdo principal
Asus Q552UB-BHI7T12 Screen Replacement
O que você precisa
  1. Asus Q552UB-BHI7T12 Screen Replacement, Screen: passo 1, imagem 1 %32 Asus Q552UB-BHI7T12 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Remove the two screw covers by hand or by using the pointed end of a spudger.
  2. Asus Q552UB-BHI7T12 Screen Replacement: passo 2, imagem 1 %32
    • Remove both screws with a Phillips head screwdriver.
  3. Asus Q552UB-BHI7T12 Screen Replacement: passo 3, imagem 1 %32 Asus Q552UB-BHI7T12 Screen Replacement: passo 3, imagem 2 %32
    • Wedge an opening tool between the two halves of the screen.
    • Keep the two latches together and go completely around the screen to release all the latches.
  4. Asus Q552UB-BHI7T12 Screen Replacement: passo 4, imagem 1 %32 Asus Q552UB-BHI7T12 Screen Replacement: passo 4, imagem 2 %32
    • Separate the two parts of the screen.
  5. Asus Q552UB-BHI7T12 Screen Replacement: passo 5, imagem 1 %32
    • Remove any tape that is holding the screen in place.
  6. Asus Q552UB-BHI7T12 Screen Replacement: passo 6, imagem 1 %32 Asus Q552UB-BHI7T12 Screen Replacement: passo 6, imagem 2 %32
    • Use an opening tool to lift out the screen after all the tape is removed.
    • The screen may be stuck due to any tape or any remaining glue.
  7. Asus Q552UB-BHI7T12 Screen Replacement: passo 7, imagem 1 %32
    • Pull the screen horizontally away to remove the last cable attached to the screen.
Conclusão
Follow these instructions in reverse order to reassemble your device.
2 comentários
Can you show the connection on motherboard for LCD cable?
Bustelo Pilon - Responder
Does anyone know where I can get this same model replacement?
Anthony C - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 953
