Ir para o conteúdo principal
Asus Q552UB-BHI7T12 Battery Replacement
O que você precisa
  1. Asus Q552UB-BHI7T12 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove all ten screws on the back of the laptop to remove the cover.
    • Remove the cover.
  2. Asus Q552UB-BHI7T12 Battery Replacement: passo 2, imagem 1 %32 Asus Q552UB-BHI7T12 Battery Replacement: passo 2, imagem 2 %32
    • Disconnect the wires at the top of the battery by lifting on the tabs protruding out of the plastic frame.
  3. Asus Q552UB-BHI7T12 Battery Replacement: passo 3, imagem 1 %32
    • Remove the four screws holding the battery in place, two on top and one on each side.
  4. Asus Q552UB-BHI7T12 Battery Replacement: passo 4, imagem 1 %32
    • Gently lift out the battery by the side closest to the motherboard first.
    • Be careful of any extra wires that may have attached itself to the battery.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Greetings I have tried to pull the battery out but i have issues making it go out of the place where it clicks, could you make a detailed video on how to safely remove that part without breaking the wires or the soldering on the board???
jorgealanhurtado95 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 3,257
