Ir para o conteúdo principal
Asus Q551L Repair Optical Drive Replacement
O que você precisa
  1. Asus Q551L Repair Optical Drive Replacement, Back Panel: passo 1, imagem 1 %32 Asus Q551L Repair Optical Drive Replacement, Back Panel: passo 1, imagem 2 %32
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Optical Drive Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32 Asus Q551L Repair Optical Drive Replacement, Optical Drive: passo 3, imagem 2 %32 Asus Q551L Repair Optical Drive Replacement, Optical Drive: passo 3, imagem 3 %32
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 680
