Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
Use the plastic opening tool to pry the back panel off the base of the laptop.
Un-clip both wire clips on the upper and right side of the battery.
Lift the battery out of the device.
Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
Remove the fan by unscrewing the nine screws shown in the images.
The four colored wire and the black cable need to be pulled out gently.
Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
Disconnect any cables that hold the motherboard.
Open up the white adjustable latch first to pull out the tapes.
Um comentário
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
