Introdução
These steps will show you how to remove the hard drive from you computer.
You will need to do that if the hard drive is in a good condition but the computer is not, replace it to a new one to increase the speed and capacity, or the hard drive has experienced a hardware failure.
O que você precisa
Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
6 outras pessoas executaram este guia.
