Introdução
If your laptop will not load multiple pages or applications at the same time, it takes a long time to load any webpages, or the laptop overall runs very slow, the RAM may need to be replaced. In this guide, we will show you how to replace the RAM.
O que você precisa
Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
Push both metal tabs away from each other on each side of the RAM farthest from battery so that the RAM will pop up.
4 outras pessoas executaram este guia.
