Ir para o conteúdo principal
Asus Q550LF-BBI7T07 Disc Drive Replacement
O que você precisa
  1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: passo 1, imagem 1 %32 Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: passo 1, imagem 2 %32
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 2, imagem 1 %32 Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 2, imagem 2 %32
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 3, imagem 1 %32 Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 4, imagem 1 %32 Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 4, imagem 2 %32
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: passo 5, imagem 1 %32 Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: passo 5, imagem 2 %32
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 6, imagem 1 %32 Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 6, imagem 2 %32
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: passo 7, imagem 1 %32 Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: passo 7, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 8, imagem 1 %32
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 9, imagem 1 %32 Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 9, imagem 2 %32
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 10, imagem 1 %32 Asus Q550LF-BBI7T07 Disc Drive Replacement: passo 10, imagem 2 %32
    • Slowly slide out the disc drive, keeping it level, to remove it.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 425
