Introdução
If your battery does not hold a charge or is having issues with battery life, it may need to be replaced. In this guide, we will show you how to replace the battery.
O que você precisa
Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
4 outras pessoas executaram este guia.
