Ir para o conteúdo principal
Asus Q534U Wi-fi card Replacement
O que você precisa
  1. Asus Q534U Wi-fi card Replacement, Back Case Removal: passo 1, imagem 1 %32
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U Wi-fi card Replacement: passo 2, imagem 1 %32 Asus Q534U Wi-fi card Replacement: passo 2, imagem 2 %32
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U Wi-fi card Replacement: passo 3, imagem 1 %32 Asus Q534U Wi-fi card Replacement: passo 3, imagem 2 %32
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U Wi-fi card Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U Wi-fi card Replacement, Wi-Fi card: passo 5, imagem 1 %32
    • Disconnect the WiFi antenna cables by gently pulling them in an upwards motion.
    • Needle nose pliers can be used as a detaching tool.
  6. Asus Q534U Wi-fi card Replacement: passo 6, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the screw holding the WiFi card down.
    • Pull the WiFi card out of the socket toward the fan housing.
Conclusão
Uma outra pessoa concluiu este guia.
Eric Okoko
Membro desde: 10/19/17
327 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 Membro de UMass Dartmouth, Team S66-G6, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 2,767
