Introdução
This guide will go over the process of removing and replacing the CPU fan and heat sink assembly.
O que você precisa
Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
Pull off the back cover of the laptop.
Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
4 outras pessoas executaram este guia.
