Ir para o conteúdo principal
Asus Q534U CPU Fan/Heat Sink Replacement
O que você precisa
  1. Asus Q534U CPU Fan/Heat Sink Replacement, Back Case Removal: passo 1, imagem 1 %32
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U CPU Fan/Heat Sink Replacement: passo 2, imagem 1 %32 Asus Q534U CPU Fan/Heat Sink Replacement: passo 2, imagem 2 %32
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U CPU Fan/Heat Sink Replacement: passo 3, imagem 1 %32 Asus Q534U CPU Fan/Heat Sink Replacement: passo 3, imagem 2 %32
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U CPU Fan/Heat Sink Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: passo 5, imagem 1 %32 Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: passo 5, imagem 2 %32
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  6. Asus Q534U CPU Fan/Heat Sink Replacement: passo 6, imagem 1 %32 Asus Q534U CPU Fan/Heat Sink Replacement: passo 6, imagem 2 %32
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
Conclusão
4 outras pessoas executaram este guia.
mmedina
Membro desde: 04/07/16
749 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 Membro de UMass Dartmouth, Team S66-G6, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G6
Membros da 3
Autoria de 5 guias
Um comentário
Is it possible to replace the fan only without removing the full heatsink or is it fused together as one unit?
Bork Bois - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Duração total: 2,899
