Ir para o conteúdo principal
Asus Q525U Hard Drive Replacement
O que você precisa
  1. Asus Q525U Hard Drive Replacement, Back Cover: passo 1, imagem 1 %32 Asus Q525U Hard Drive Replacement, Back Cover: passo 1, imagem 2 %32 Asus Q525U Hard Drive Replacement, Back Cover: passo 1, imagem 3 %32
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
  2. Asus Q525U Hard Drive Replacement: passo 2, imagem 1 %32 Asus Q525U Hard Drive Replacement: passo 2, imagem 2 %32 Asus Q525U Hard Drive Replacement: passo 2, imagem 3 %32
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
  3. Asus Q525U Hard Drive Replacement: passo 3, imagem 1 %32 Asus Q525U Hard Drive Replacement: passo 3, imagem 2 %32 Asus Q525U Hard Drive Replacement: passo 3, imagem 3 %32
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
  4. Asus Q525U Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • The hard drive is located to the left of the battery and below the motherboard.
  5. Asus Q525U Hard Drive Replacement: passo 5, imagem 1 %32 Asus Q525U Hard Drive Replacement: passo 5, imagem 2 %32
    • Remove the two 4 mm Phillips #1 screws which are holding the hard drive cover in place.
  6. Asus Q525U Hard Drive Replacement: passo 6, imagem 1 %32 Asus Q525U Hard Drive Replacement: passo 6, imagem 2 %32
    • The hard drive cover is now easily accessible.
    • Lift the cover off, exposing the hard drive underneath [this laptop is missing its hard drive].
    • If replacing the hard drive, lift it up on the right side slightly and pull it from the connecter on the left.
Conclusão
Uma outra pessoa concluiu este guia.
Stewart Crandall
Membro desde: 02/22/22
550 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 2-5, Hunter Spring 2022 Membro de Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 72
Duração total: 2,077
