Introdução
Is your Asus Q525U laptop unable to hold a charge or power up without being connected to a charging cord? Follow this guide if you need to replace the battery of your Asus Q525U.
Before beginning this guide, be sure to turn off your laptop and disconnect from the power adapter.
O que você precisa
Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
The battery of the device is outlined in red.
Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
Using the Halberd spudger, carefully lift the battery connector up to disconnect it from the motherboard.
