Ir para o conteúdo principal
Asus Q525U Back Cover Replacement
O que você precisa
  1. Asus Q525U Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Asus Q525U Back Cover Replacement, Back Cover: passo 1, imagem 2 %32 Asus Q525U Back Cover Replacement, Back Cover: passo 1, imagem 3 %32
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
  2. Asus Q525U Back Cover Replacement: passo 2, imagem 1 %32 Asus Q525U Back Cover Replacement: passo 2, imagem 2 %32 Asus Q525U Back Cover Replacement: passo 2, imagem 3 %32
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
  3. Asus Q525U Back Cover Replacement: passo 3, imagem 1 %32 Asus Q525U Back Cover Replacement: passo 3, imagem 2 %32 Asus Q525U Back Cover Replacement: passo 3, imagem 3 %32
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
Conclusão
Uma outra pessoa concluiu este guia.
Stewart Crandall
Membro desde: 02/22/22
550 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 2-5, Hunter Spring 2022 Membro de Clemson, Team 2-5, Hunter Spring 2022
CLEM-HUNTER-S22S2G5
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 628
