Introdução
In this guide you will learn how to remove and replace the fan in the Asus Q505UA-BI5T7 laptop. This is a simple process with a minimal amount of tools needed.
You will need to look at the back cover removal and battery replacements guide before you will be able to remove the fan. Please be aware after following the back cover removal guide, to access the fan, you will need to also remove the battery, but do not need to detach the power connection strip.
O que você precisa
Flip the device over so that the back cover is facing you.
Remove the two 10 mm Philips #1 screws from the top two corners of the back cover of the laptop.
Remove the remaining eight 8 mm Philips #1 screws remaining in the back cover of the laptop.
Make sure your device is turned off. Remove the 5 mm screws on each respective side of the battery by twisting counter-clockwise with a #0 Phillips screwdriver.
