Ir para o conteúdo principal
Asus Q504UA-BHI5T13 Touch-pad Replacement
O que você precisa
  1. Asus Q504UA-BHI5T13 Touch-pad Replacement, Back Panel: passo 1, imagem 1 %32
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 2, imagem 1 %32
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 3, imagem 1 %32
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 4, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 5, imagem 1 %32
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Touch-pad Replacement, Battery: passo 6, imagem 1 %32
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 7, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 8, imagem 1 %32 Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 8, imagem 2 %32
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 9, imagem 1 %32 Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 9, imagem 2 %32
    • Remove the battery from the device.
  10. Asus Q504UA-BHI5T13 Touch-pad Replacement, Touch-pad: passo 10, imagem 1 %32
    • Pull the large data ribbon near the touch-pad out of the way with your hands.
    • Use the Phillips #0 screwdriver to remove the three 3.0 mm screws connecting the touch-pad to the device.
  11. Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 11, imagem 1 %32 Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 11, imagem 2 %32
    • Use the small plastic opening tool to remove the ZIF Connector on the left side of the touch-pad.
  12. Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 12, imagem 1 %32 Asus Q504UA-BHI5T13 Touch-pad Replacement: passo 12, imagem 2 %32
    • Pry the end closest to the display up with your fingers and pull the touch-pad out.
Conclusão
Jacob Fritsch
Membro desde: 11/04/19
337 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G2, Henning Fall 2019 Membro de IUPUI, Team S1-G2, Henning Fall 2019
IUPUI-HENNING-F19S1G2
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 265
