Ir para o conteúdo principal
Asus Q504UA-BHI5T13 Motherboard Replacement
O que você precisa
  1. Asus Q504UA-BHI5T13 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 2, imagem 1 %32
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 4, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 5, imagem 1 %32
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Motherboard Replacement, Battery: passo 6, imagem 1 %32
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 7, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 8, imagem 1 %32 Asus Q504UA-BHI5T13 Motherboard Replacement: passo 8, imagem 2 %32
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 9, imagem 1 %32 Asus Q504UA-BHI5T13 Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the battery from the device.
  10. Asus Q504UA-BHI5T13 Motherboard Replacement, Heat Sink: passo 10, imagem 1 %32
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing nearest to you.
  11. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 11, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the three black 4mm screws located around the heat sink fan.
  12. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 12, imagem 1 %32
    • Using the same screwdriver, remove the four 4mm black screws around the copper lining
    • First remove the screw in the red circle.
    • Then remove the screw in the orange circle.
    • Next remove the screw in the yellow circle.
    • Finally, remove the screw in the green circle.
    • For this step, it helps to remove the screws in this order to prevent damage to the heat sink.
  13. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 13, imagem 1 %32 Asus Q504UA-BHI5T13 Motherboard Replacement: passo 13, imagem 2 %32
    • Use a pair of tweezers to pull and disconnect the cable located to the right of the heat sink fan.
    • Take caution when removing the cable. Damaging the cable will stop the part from working.
  14. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 14, imagem 1 %32
    • Carefully unravel the cables (two black and one white) to the left of the heat sink fan.
  15. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 15, imagem 1 %32
    • Remove the heat sink from the device.
  16. Asus Q504UA-BHI5T13 Motherboard Replacement, Hard Drive: passo 16, imagem 1 %32
  17. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 17, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the eight 4mm screws around the hard drive casing (located next to the Right [R] speaker).
    • Start off with the four black outer screws so that the casing can be released from the laptop unit.
    • The next sequence of screws to remove are the four silver screws.
  18. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 18, imagem 1 %32
    • Remove the cover.
  19. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 19, imagem 1 %32 Asus Q504UA-BHI5T13 Motherboard Replacement: passo 19, imagem 2 %32
    • Lift the hard drive and disconnect the hard drive sliding connector.
    • Be careful when removing the connector from the hard drive, as damaging that cable could cause damage to the hard drive.
  20. Asus Q504UA-BHI5T13 Motherboard Replacement, Motherboard: passo 20, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the remaining eight 4.0 mm screws.
  21. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 21, imagem 1 %32 Asus Q504UA-BHI5T13 Motherboard Replacement: passo 21, imagem 2 %32
    • Remove the wifi card by hand, as shown.
  22. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 22, imagem 1 %32 Asus Q504UA-BHI5T13 Motherboard Replacement: passo 22, imagem 2 %32 Asus Q504UA-BHI5T13 Motherboard Replacement: passo 22, imagem 3 %32
    • Use the small plastic opening tool to remove the three ZIF Connectors.
  23. Asus Q504UA-BHI5T13 Motherboard Replacement: passo 23, imagem 1 %32 Asus Q504UA-BHI5T13 Motherboard Replacement: passo 23, imagem 2 %32 Asus Q504UA-BHI5T13 Motherboard Replacement: passo 23, imagem 3 %32
    • Pull up on two corners and pull upwards to remove the Motherboard.
Conclusão
Jacob Fritsch
Membro desde: 11/04/19
337 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G2, Henning Fall 2019 Membro de IUPUI, Team S1-G2, Henning Fall 2019
IUPUI-HENNING-F19S1G2
Membros da 3
Autoria de 3 guias
Um comentário
Is there a replaceable ram stick on the other side of the motherboard? It looks like there is only one slot on the top side.
David Reagan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 844
