Introdução
The display of the Asus Q504UA-BHI5T13 device can be replaced when the laptop is no longer displaying a clear image. The repair is done by removing the display assembly. This guide will show the instructions on how to remove the back panel, hinges, and two connectors holding the Display Assembly.
O que você precisa
Use the Phillips #0 screwdriver to remove the six 5.00 mm screws connected to the hinges of the display assembly.
