Ir para o conteúdo principal
Asus Q503UA Battery Replacement
O que você precisa
  1. Asus Q503UA Battery Replacement, Battery Replacement: passo 1, imagem 1 %32
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA Battery Replacement: passo 2, imagem 1 %32 Asus Q503UA Battery Replacement: passo 2, imagem 2 %32
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA Battery Replacement: passo 3, imagem 1 %32 Asus Q503UA Battery Replacement: passo 3, imagem 2 %32 Asus Q503UA Battery Replacement: passo 3, imagem 3 %32
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
Conclusão
To reinstall the back cover, follow these instructions in reverse order.
5 outras pessoas executaram este guia.
Equipe
Gateway, Team S1-G4, Saknee Fall 2019 Membro de Gateway, Team S1-G4, Saknee Fall 2019
GCC-SAKNEE-F19S1G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 463
