Introdução
The keyboard allows communication between the user and the laptop. If your keyboard is not responding, follow this guide to learn how to replace it.
O que você precisa
Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
Remove the one 5 mm Phillips #1 screw.
Pull out the green plastic in order to free the keyboard underneath.
Uma outra pessoa concluiu este guia.
Um comentário
Step 4 was misleading. It should have unplugged the cable before lifting the battery. I broke my battery connector off the mobo by following these directions. Lift straight up? That’s silly given how short the battery connection cable is.
