Ir para o conteúdo principal
Asus Q502LA-BSI5T14 Keyboard Replacement
O que você precisa
  1. Asus Q502LA-BSI5T14 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 2, imagem 1 %32
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 3, imagem 1 %32 Asus Q502LA-BSI5T14 Keyboard Replacement: passo 3, imagem 2 %32
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 4, imagem 1 %32 Asus Q502LA-BSI5T14 Keyboard Replacement: passo 4, imagem 2 %32
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
  5. Asus Q502LA-BSI5T14 Keyboard Replacement, Motherboard: passo 5, imagem 1 %32 Asus Q502LA-BSI5T14 Keyboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Remove the four ribbons connected to the motherboard.
  6. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 6, imagem 1 %32 Asus Q502LA-BSI5T14 Keyboard Replacement: passo 6, imagem 2 %32
    • Disconnect the five wires attached to the motherboard by pulling gently. There are three thin wires in the upper left corner.
  7. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 7, imagem 1 %32
    • Remove the two 5 mm Phillips #1 screws attaching the stabilizer to the motherboard
  8. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 8, imagem 1 %32
    • Remove the four 5 mm Phillips #1 screws around the perimeter of the motherboard.
  9. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 9, imagem 1 %32 Asus Q502LA-BSI5T14 Keyboard Replacement: passo 9, imagem 2 %32
    • Remove the six 5 mm Phillips #1 screws securing the silver plates to the motherboard.
    • Open the laptop approximately 1/2" to loosen the hinge and release the motherboard.
  10. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 10, imagem 1 %32
    • Gently lift the motherboard out and away from the laptop.
  11. Asus Q502LA-BSI5T14 Keyboard Replacement, Keyboard: passo 11, imagem 1 %32 Asus Q502LA-BSI5T14 Keyboard Replacement, Keyboard: passo 11, imagem 2 %32
    • Remove the one 5 mm Phillips #1 screw.
    • Pull out the green plastic in order to free the keyboard underneath.
    • It is not necessary to unattach the green plastic completely .
  12. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 12, imagem 1 %32 Asus Q502LA-BSI5T14 Keyboard Replacement: passo 12, imagem 2 %32
    • Start peeling the black cover from the bottom left corner gently.
    • Continue until the black cover is fully removed.
  13. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 13, imagem 1 %32 Asus Q502LA-BSI5T14 Keyboard Replacement: passo 13, imagem 2 %32
    • Insert black Spudger in bottom left corner and lift the keyboard up.
    • Slide the black Spudger underneath the keyboard to loosen it.
    • Little black pieces that hold the keyboard in place will pop out while you lift the keyboard up.
    • This part is difficult and requires a gentle but forceful movement.
  14. Asus Q502LA-BSI5T14 Keyboard Replacement: passo 14, imagem 1 %32
    • Lift up the keyboard once it is loosened to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Mary Kounelas
Membro desde: 09/25/17
715 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S4-G1, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
Membros da 4
Autoria de 5 guias
Um comentário
Step 4 was misleading. It should have unplugged the cable before lifting the battery. I broke my battery connector off the mobo by following these directions. Lift straight up? That’s silly given how short the battery connection cable is.
Stevo Dumpert - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 977
